Shaft Speed Sensor Circuit help please
Old May 24, 2010 | 07:25 PM
  #21
Default 2001 ACCENT--- different repair procedure
TSB says to ohm test the output speed sensor, over 275 ohm, replace the sensor, and reprogram the TCM with #18 -- "LC AT VSS NOISE IMPROVEMENT"..
Resistance value: 215-275 ohm (at 20°C or 68°F)
Do # 18, then chase it with #30 for shudder from p - r - d
TCM REPROGRAMMING PROCEDURE:
While you is still connected, add #52 for Ox logic, #84 for thermostat diagnostic logic..
Hi-Scan is the old way, GDS is the new way, it'll prompt tech to what connectors to use..
Old May 24, 2010 | 09:36 PM
  #22
j_vigue_99's Avatar
What are the odds that my local mechanic is going to be able to do that? and if not what would it cost (ballpark) to have it done at a dealership? Ive already replaced the sensor.
Old May 25, 2010 | 05:54 AM
  #23
Programs is proprietary info... gots to visit the local HYUNDAI franchise
Old Jul 14, 2010 | 09:32 PM
  #24
WMMMCM's Avatar
Question More help please
I started working on this car over a year ago. Just a few days after fixing the Shaft Speed Sensor I had troubles again. I never really got the car working again. Now I need to get it fixed or get rid of it. It has been sitting for a year. I added water to the radiator, checked the oil and replaced the battery. I get the check engine light right after I start to drive it. I do not get any codes when I hook up the tool to check the codes. When I go to take off, the car sputters a bit before it goes. It seems that once it gets into second gear it is fine. The problem comes when you come to a stop. It seems that unless you wait for a couple of seconds, the car does not go into first gear and takes off in second. This is where the sputtering comes in. The car will sometimes also have a hard time idling. I think that it is because it is still in second gear but I am not sure. Any help would be appreciated.
Old Jul 29, 2010 | 01:55 PM
  #25
WMMMCM's Avatar
Talking Please help
I still can not get the car to shift in first gear. Do I need to take it to Hyundai to reset the TCM or is my next step to replace the speed sensor?
I am so lost now.
Thanks,
WMM
Old Jul 29, 2010 | 11:47 PM
  #26
mikeross's Avatar
Thanks for posting the codes. It sure helped me alot. My speed sensor has been sending a certain error code i do not know of.
racing1219
Aug 29, 2014 06:56 AM
sivyer2081
Jun 20, 2009 11:54 PM
Steviemags
Apr 21, 2008 07:26 PM
leiladrue
Mar 10, 2007 10:09 PM
