Hyundai Coupe The European version of the American Tirburon.
No tail lights!
Old Jan 2, 2008 | 10:48 PM
de2r's Avatar
Default No tail lights!
I really hope someone can point me in the right direction on this. I suck at electrical problems. The story so far ....
The car is a 1993 SCoupe Turbo. My son bought this as a secondary vehicle for the winter.
Headlights work -buthe hasno tail lights, parking lights or dash lights. I'm suspecting that this all is on the same circuit. I have checked the fuse panel under the dash and didn't see a fuse designated for the tail lights or the cluster. I checkedthe fusible links under the hood and they're good. I checked the tail light bulbs and the filiments are in tact. I checked the ground for thislighting assembly and its good. I bought the only manual I've seen available on this vehicle -the Chilton Hyundai Coupes/Sedans 1986 - 93. It might as well be in latin because the book is vague at best. Does anyone have any suggestions or methods I could try to pinpoint the problem and fix it. He just moved out and needs the car to commute.
Thanks in advance.
Old Jan 3, 2008 | 02:57 PM
madindian1's Avatar
Default RE: No tail lights!
i'm not really familiar with the car but if all fuses and bulbs are good, use a test light and check at the sockets to see if you're getting power/voltage. that way you can back track, check behind the socket and remove the bulb to see if it's a voltage problem or faulty socket. it could also be a connector both harnesses plug into for the tail lights. just my 2 cents
Old Jan 3, 2008 | 06:36 PM
de2r's Avatar
Thanks madindian1. I thought about that today. I was hoping it would be a simple burnt fuse somewhere.
Old Jan 4, 2008 | 06:08 PM
madindian1's Avatar
no problem
psychodoodbrij92
Mar 28, 2019 11:54 AM
msvg
May 25, 2006 12:29 AM
GFont
May 14, 2006 07:14 PM
msvg
Jan 27, 2006 03:11 PM
accentgsi02
Nov 29, 2005 09:57 PM
