Suspension Talk about your suspension within.
2002 Elantra Suspension Question
Old Jul 21, 2008 | 10:40 AM
excaliboar's Avatar
Default 2002 Elantra Suspension Question
My 02 Elantra, 130k, is making a thumping noise that is associated w/ speed and seems to be coming from the driver's side rear. Just had tires replaced, and they had an uneven wear pattern around the circumference of the tire. Tire shop did an alignment, but said I may have a strut issue. Any ideas of other possible problems? How would I go about replacing struts?
Old Jul 21, 2008 | 10:51 AM
Default RE: 2002 Elantra Suspension Question
You need to remove the strut and spring from the car. Have the spring compressed and removed then add the spring to the new strut and install the new strut/spring. Check http://www.hmaservice.com for the procedure.
molayne17
May 18, 2021 10:01 PM
DSG
Nov 3, 2018 02:08 AM
roanoke10
Jun 22, 2013 09:51 AM
excaliboar
Jul 18, 2008 10:01 AM
geoffcantley12
Apr 5, 2008 03:47 PM
