Other Hyundai Models This section is for any older European or American models that we may have excluded.
Key Getting Stuck
Old Sep 20, 2008 | 07:54 PM
deadwoman13's Avatar
Default Key Getting Stuck
I got a 93 Excel just got other day and when we put the key in it turns no prob at all. But then when you go to turn switch off it won't let you turn it past ACC. But if you unhook Battery then it will let you turn it to off with no problem and take key out. So does anyone know what the problem could be and how to fix it?
Old Sep 20, 2008 | 10:28 PM
Default RE: Key Getting Stuck
I assume the car has an automatic tranmission. I think you have a bad neutral safety switch that's built into the shifter mechanism. The switch prevent you from starting the unless the shifter is engaged in either the park or neutral position, and prevents the key from turning to the lock position for removal unless the shifter is in the park position. When you disconnect the battery, the lockout solanoid losses power and stops working.
svaken55
Oct 5, 2010 10:39 PM
stefaniej513
Jul 14, 2010 10:45 PM
stehlar24
Dec 3, 2008 09:01 PM
first choice
Jun 6, 2006 10:18 PM
