2006 Hyundai Elantra fuel filter location
Old Oct 26, 2008 | 12:52 PM
tawna5110's Avatar
Default 2006 Hyundai Elantra fuel filter location
Can anyone tell me where the fuel filter is located on a 2006 Elantra? Also, my check engine light is blinking, and my car is having low rpm issues. At times, the car dies, and then it will turn over, but not start. Anyone have any ideas?
Old Oct 26, 2008 | 12:53 PM
tawna5110's Avatar
Default RE: 2006 Hyundai Elantra fuel filter location
PS: Does the fuel tank have to be dropped to change the fuel filter and/or pump?
Old Oct 26, 2008 | 01:18 PM
The filter is part of the fuel pump assembly mounted in the tank.
No, there should be a cover or plate under the back seat that when removed, provides access to the top of the fuel tank where the pump is installed.
You need to have a code scanner hooked up to the vehicle to extract the error codes from the engine control module. Many auto parts stores will perform this service for free or a nominal cost. You should do this first to figure out what the problem may be before swapping parts for no good reason.
I suspect you may have a failing crankshaft rotation sensor (which cuts off both fuel and spark to the engine when not functioning). A good scanner will pull the code(s) and run diagnostics on the sensor as well.
Old Oct 28, 2008 | 08:28 AM
tawna5110's Avatar
Hi Ken,
Thank you for your response! I had the code read, and it told me that the O2 sensor should be replaced. I replaced the sensor, and no luck!
Old Oct 28, 2008 | 10:13 AM
What was the code? Did you change the correct O2 sensor? There are 2; one before the cat and one after.
Paulus
Mar 11, 2013 10:29 AM
Aggie_1990
Jan 17, 2012 12:28 PM
77cj7
Jan 18, 2009 11:58 PM
TONTOE2004
Nov 1, 2008 04:46 PM
NOVELOSERGIO
Dec 31, 2007 07:58 PM
