Hyundai Matrix This sub compact hatchback offers excellent interior room for both passengers and cargo.
Matrix cylinder head gasket repalcement
Old Nov 16, 2008 | 10:02 PM
edgarnn's Avatar
Default Matrix cylinder head gasket repalcement
we had our matrix cylinder head gasket replaced, but the replacement part purchased from Hyundai is thicker than the original part (ORIGINAL part is consist of two pcs gasket, the replacement is consist of 4 pcs gasket. what is the effect if we use the thicker part or should we discard the other gasket to just use two piece. please help.
Old Nov 24, 2008 | 09:50 AM
Default RE: Matrix cylinder head gasket repalcement
I think you are confused with head gasket vs. valve cover gasket. Also, you are saying you replaced the gasket, then allude to still needing to replace it. Can you clarify your post? You might get a meaningful response that way.
miketheitalian
Feb 4, 2014 05:15 PM
Cruzian
Aug 22, 2009 12:18 PM
jimber57yr
Sep 11, 2008 08:55 PM
Zef_66
Mar 18, 2008 10:59 PM
headsupkid01
Oct 9, 2007 08:07 PM
