Hyundai Forums - Photo Galleries - Create an Account
Go Back   Hyundai Forum - Hyundai Enthusiast Forums > Brand Reviews > Suspension
Reply
Thread Tools Search this Thread
Old 12-04-2008, 10:23 PM
teachdqs teachdqs is offline
Default Rear Strut Banging on 2001 XG 350
My 2001 XG 350 makes a banging noise that has been suggested as the rear struts. This occurs when the car goes over bumps. I just replaced the rear tires which were badly cupped and made a howling noise while driving at highway speeds.
Are these struts prone to developing clunking problems with the strut mount? Can they be replaced by DIY or are specialized tools required?
Thanks for your help.
Sponsored Links
Old 01-02-2009, 08:48 AM
Skrag55 Skrag55 is offline
Default RE: Rear Strut Banging on 2001 XG 350
The rear upper strut arm is connected to the strut housing by 14mm bolts. The threads on the strut housing are welded in place these usually break causing the upper arm to move around when going over bumps. The only special tool you will need is a spring compressor.
Old 01-02-2009, 09:39 AM
NovaResource NovaResource is offline
2006 Hyundai Tucson
My Garage
Are the struts original? How many miles are on the struts? If they are original, it's time to replace the 8 year old struts.
Old 01-02-2009, 02:37 PM
jsinton jsinton is offline
If the tires are cupping, then probably the struts are bad and need to be replaced. Replacing the struts is a good time to check to see if any of the mounting bolts are loose, which is probably the cause of the banging. Skrag55 is correct, it's not a big deal to replace them yourself, you just need a spring compresser. I think Autozone will lend the spring compressor for free if you buy the struts there.
[align=left] [/align]
__________________
The Martyr
Reply
Tags
2001, accent, back, banging, bumps, clunking, cost, getz, hyundai, noise, rear, replacing, strut, struts, xg, xg350
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
Honda Accessories
- Headlights & Tail Lights
- Outdoor Car Cover
- Auto Detailing Supplies
- Honda Floor Mats
- Honda Seat Covers
- Dash Cover | Auto Mats
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
