New alloys rubbing!!
Old Nov 1, 2005 | 07:09 AM
hopoffbaby's Avatar
Default New alloys rubbing!!
I have just put a set of 15" fox racing alloys on my '99 accent. however when there is a load in the back or i go over a bump i hear a grinding/rubbing sort of noise from the rear drivers side wheel. it may be the other side aswell but at the moment i can only hear the drivers side.
i have also gone up a few sizes in tyres. from 175/65 R14 to 195/55 R15.
Has anyone got any ideas as how to best solve the problem. Thanx
Neil
Old Nov 1, 2005 | 09:49 PM
poacher's Avatar
Default RE: New alloys rubbing!!
Get a lower profile tire. Or buy a stiffer suspension.
Old Nov 10, 2005 | 04:58 PM
hopoffbaby's Avatar
I am now completly stuck on this.
Ok the wheel was rubbing on the suspension arm. i fitted some 3mm spacers and this fixed the grinding problem.
now whenever i go over a bump or round a cornder it sounds like it is rubbing on the arches itself.
I have now had to resort to fitting the old wheels.
any ideas?
Old Nov 10, 2005 | 05:48 PM
Brant's Avatar
Hopoff,
You went from a 14 inch wheel to a 15 inch = (-1 inch) of clearance, then you went from a low profile 14' tire to a higher profile 15' tire. Now I'm thinkin' and I could be wrong but, if you kept 15' rims and went with a 175/65 R15 tire, it might work but, then again I don't know what the offset number on the rim you bought. Now with that all said and done & your scratching your head mumbling, "what the heck?" to yourself. You need a lower profile tire.
Hope this helps,
Brant
Old Nov 11, 2005 | 12:22 AM
poacher's Avatar
That is the issue. When you are increasing the diameter of the rim, for proper fitting you MUST decrease the height of the sidewall of the tire.
Old Nov 11, 2005 | 08:59 AM
hopoffbaby's Avatar
thanks for the replys.
the alloys i brought are 15" fox racing evo 3.
http://www.custom-wheels-rims-alloys...eels-rims.html
dont know if this helps.
i am rubbish with tyre sizes. i though i had gone down in diamiter but up in width.
what sizes would you recomend?
Old Nov 11, 2005 | 10:47 AM
Brant's Avatar
hopoff,
you can probably stay with the 15' rim but, go with the 175/65 or 175/55 r15 tires.
Brant
Old Nov 13, 2005 | 03:56 AM
poacher's Avatar
Brant is right, those are your best bets. I would go for the wider tire, but keep in mind that if you go to wide you may still rub.
Old Nov 14, 2005 | 07:42 PM
hopoffbaby's Avatar
Thanks guys, looks like i got to get some new tyres then. Will they fit those rims?
Old Nov 14, 2005 | 10:50 PM
poacher's Avatar
As long as the diameter and width match, then yes they will fit. Those tires suggested will most definately fit.
Ally
Nov 3, 2009 01:10 PM
RugbyPete
Feb 17, 2009 10:20 AM
spoolenturbo
Jan 3, 2008 11:54 PM
gtaa
May 13, 2007 08:50 AM
Anthony200
May 18, 2006 02:44 PM
