tire pressure monitoring
Old Aug 21, 2009 | 06:00 PM
gunwaleman's Avatar
Default tire pressure monitoring
make sure you do as the manual says and check your pressure. I was surprised to find my pressure off by about4 1/2 lbs per tire. I don't know what Hyundai means by significant pressure loss but to me that is significant. I usually do check it often but was relying on the monitor and I shouldn't have and as the manual says you shouldn't. My bad.
Old Aug 21, 2009 | 07:10 PM
Tire pressures can fluctuate by as much as 5-psi depending on temperature. This is why you need to check your tire pressured regularly and not rely on the TPMS.
HermanPWillis
Sep 20, 2011 07:32 AM
BREWSTER
Sep 8, 2009 08:51 AM
085speed
Jul 17, 2008 05:19 PM
hycustomer
May 8, 2008 07:12 AM
marcbla
Feb 24, 2007 10:53 PM
