2010 Accent radio Info.
Do you own a 2010 Accent GLS.....Does it have a radio that looks like this...
And you wished it looked like this.....
If so you will need the wiring diagram for this plug....If it is still there..
and do not forget the important stuff.. like wiring harness, If you still have a factory plug for your stereo.
This is the right one for this plug ..see attached
the wiring diagram on the back of this harness is spot on...All the wires match perfectly....including the illumination wire..
Hope it helps...
Hope it helps...
