Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. let's hear about it here.
AMP AND SUB QUESTION
Old 01-25-2009 | 08:53 PM
bucannon's Avatar
Default AMP AND SUB QUESTION
i have a 2001 sonata. at first it had a bazooka tube hooked up to the stock radio, which was done professionally by a shop before i had the car. the tube quit working so i decided to add 2 12" subs with an 800 watt Cantus banda 2800amp. it had speaker level rca inputs for the amp, and the remote is hooked up to the ignition. so when i installed an Eiger Vision EV-4300N radio, i decided to run line level rca inputs for the amp. i thought the bass would be less distorted and harder hitting.
with the new radio the 4 regular speakers are louder but the subs dont seem to be as good as they should, one sub is an Impulse 300 watt. the other is an Earthquake 250 watt. i know this is not enough speaker forthe amp i have so the amp is turned down, but it should be hard hitting. how can i get the bass to hit so hard that your voice sounds electronic(if you talk while the sub is whamming).
Old 08-26-2009 | 02:31 PM
taxlienusa's Avatar
does the radio have a deicated subwoofer output rca ? If you are using the line levels then turn up the line level output, if you bought a quality box it will have a adjustment point. If not buy a better line level at a local walmart or online for $10. That will boost the signal. Then turn up the amp outputs until your bass has more punch to it. A 300 watt bass amp is fine for up to a 10" sub.
Old 10-21-2009 | 08:09 PM
Shyguy64's Avatar
Default subs
sometimes when using 2 different subs that are different wattage you have the chance of cancellation of frequencies due to different frequencies. try hooking up your 2 subs bridged but i suggest geting 2 alike subs
Tagoo
12-06-2011 02:56 PM
Abstract Hero
07-29-2011 11:12 AM
buford098
05-23-2009 04:32 PM
YKPAIHA
01-07-2007 01:25 AM
customboxman
06-18-2006 12:15 PM
