Engine & Internal Chat about beefing up your engine's insides here.
Emmissions
Old 12-06-2004 | 08:33 PM
C i Black's Avatar
Default Emmissions
<FONT face="Arial, Helvetica, sans-serif" size=4>Can anyone help I have an older lantra and I am having a problem reducing CO emmissions at fast idle 2300 rpm. Natural idle is ok at 0.45 Fast idle 0.51</FONT></P>
<FONT face=Arial size=4>Have changed Lambda sensor, plugs, ignition leads, and oil treatment to help compression. None of these changes made any difference whatsoever. Please advise.</FONT></P>
<FONT face=Arial size=4> <IMG style="CURSOR: pointer" onclick="AddSmileyIcon'smileys/smiley19.gif'" height=20 alt=Cry src=smileys/smiley19.gif width=15 border="0"> </FONT></P>
Old 06-17-2005 | 03:46 AM
pure performance's Avatar
Default RE: Emmissions
First off a high CO count indicates a rich a/f mixture.
Second- is the car fuel injected or carburated?
Their could be a bad vacuum linegoing to your fuel psi regulator, check all vacuum lines.
Catilytic converter might be bad also
fuel injector stuck open
pluged air filter
cylinder missing or dead
These are a few things to ponder
Tony
Old 10-22-2005 | 10:53 PM
poacher's Avatar
My first guess would be that the problem is exhaust related. If you had a dead piston you would notice as well as a stuck injector. I am willing to go with a bad catalytic converter, I hope you didn't remove it, that is usually a number one culprit.
bek0r
12-07-2005 05:55 PM
Tiburon100
12-06-2005 07:17 PM
poocheymama
11-02-2005 04:08 PM
neta
01-21-2005 01:23 AM
scrutineer
10-25-2004 09:36 PM
