hi, want to install an Elantra 2.0 engine in a scoupe using the accent gearbox, any advice
RE: hi, want to install an Elantra 2.0 engine in a scoupe using the accent gearbox, any advice
hi my friend well let give give you an advice a have a 2.0 tiburon engine on my accent you are going to need the ecu harness of a 96-99 hyundai accent cause the tiburon ecu doesnt fit on the scoupe one you are going to need tiburon or elantraflywheel and the pressure plateyou are going to use are these options scoupe turbo , mitsubishi mirage 97-2001 and the clutch can be tiburon or mirage 97-2001 and that will fit like factory the transmission will fit perfectly
oohh another tip the elantra 1.8 flywheel is a little bit lighter than 2.0 engine i can give you some tips if you need some help be free to ask i hope this help you bro
jbluemke
02-19-2015 08:31 PM
formula40
01-18-2009 04:58 PM
