03 1.6 will not fire up, no start
Old 06-22-2009 | 01:10 AM
red13's Avatar
Default 03 1.6 will not fire up, no start
I am working on my 03 accent, its the DOHC 1.6 auto. It will not fire up, just cranks and cranks. Did a compression test 180-160 all around, timing belt is new and looks good, has fuel pressure, has spark, fuel pump sounds good. Replaced the crank positioning sensor, what next?
Old 06-22-2009 | 06:33 AM
jsinton's Avatar
Banned
Did you do a code scan? That's the first thing to do in this situation.
Old 06-26-2009 | 03:06 PM
red13's Avatar
Yea ran the codes, but they got erased when I pulled the + terminal previously. No codes are there now, the tester indicated the ecu has not ran all its test's (no way to now that the engine will not start).
Old 06-26-2009 | 03:47 PM
jsinton's Avatar
Banned
Camshaft position sensor controls fuel injector valves. I'm willing to bet that's the problem, as you have spark (crank sensor) and fuel pressure.
A hard lesson learned: Pull the codes first and write them down.
zcuban1
11-16-2011 07:26 AM
mattroth7474
11-10-2011 03:00 PM
NeverKnowEnough
11-25-2010 04:41 AM
victor
05-02-2006 10:04 PM
timber
03-31-2005 03:15 PM
