04 Sonata 2.4 DOHC code po 102
Old 03-17-2008 | 09:39 AM
chestnut1's Avatar
Default 04 Sonata 2.4 DOHC code po 102
My car runs like s>>t ,turned on check engine light,checked code with code reader ,shows po102,( mass air flow) low volumn ,does this mean I need to replace it ? air filter is clean ,can see no dust or anything else in the hose ,all looks clean an conection is good an clean , thanks for any advice Chestnut1[:@]
Old 03-17-2008 | 10:46 AM
Default RE: 04 Sonata 2.4 DOHC code po 102
Yeah, the MAF is probably bad and needs to be replaced. Get it checked first.
Old 03-18-2008 | 08:41 AM
chestnut1's Avatar
Hi , had it tested an its bad,Now the fun part is the local dealer doesn't have one ,they said it would take 3 days to get an 275 for the part an they wanted 165 to install it Ha Ha , two hose clamps an one elc. plug, Don't think so , may end up having to buy from them because there is no aftermarket supplier around that has one either. What PIA this one is . Thanks for the advice Chestnut1[:'(]
Old 03-18-2008 | 03:07 PM
Isn't your car still under warranty? It's still less that 5 years old even if it's used? The MAF shoudl be covered under the 10/100K warranty for the original owner or the 5/60K for the 2nd owner.
Old 03-19-2008 | 11:15 AM
chestnut1's Avatar
No not under warranty, the wife works 75 miles away an that is one way so she put on 3grand a month,Now has160k on it , found a maf at a junk yard in Vegas for 80 bucks ,Ha works great an saved a few bucks. Been a good car but will never buy another. the valve of them sucks . thanks Chestnut1
nopdswat
09-12-2010 11:53 PM
bboystunts04
06-11-2010 11:15 AM
satanstoystore
03-15-2007 03:10 PM
ARKracing
12-07-2005 04:28 PM
kar king
02-12-2005 02:51 PM
