2000 Elantra PCM
2000 Elantra PCM
Has anyone tried to remove the Powertrain Control Module from a 2000 Elanta? I have a Haynes manual for this car but the info in it is bogus. It says to swing the latch that holds the connector on , then pull the module down and disconnect the connector and then slide the PCM out of the mount.
I can swing the latch down, but the module won't come out and the left hand end of the connector won't disconnect.
Any ideas????
Any ideas????
bryanbuchi
02-27-2009 07:42 PM
2000, connecter, control, elanta, elantra, hyundai, location, module, moduloe, pcm, power, powertrain, powertraincontrol, replacement, xg350
