2000 Sonata will not start
Old 07-07-2007 | 08:59 PM
rebhan's Avatar
Default 2000 Sonata will not start
Good Evening All
I am having problems troubleshooting a problem with a 2000 Sonata 2.5L 6 cylinder. The car was having idling problems for approx. one week. It would occasionally die in traffic but would immediately re-start. A couple days ago the car was idling poorly - drove into a service station - poured a bottle of heat into the gas tank and tried to start the car. The car refused to start. Had the car towed home.
Trouble codes as follows:
P1505 - Idle air control at adaptive clip
P1507 - Idle air control underspeed error
P0445 - Evaporator Canister Large Leak
I removed the idle air control valve, cleaned the unit and re-installed.
I have also confirmed that I do not have spark at the plugs and I do not have power at the fuel pump.
Battery power is OK. I removed the ECM - board looks and smells OK.
Can anybody help with this problem?
Is the ECM bad?
Would a bad crankcase sensor cause all of these problems?
Does anybody have an electrical schematic with interlocks for the ECM?
Thanks.
Jim R.
chasake
04-21-2020 05:09 PM
dgaringer
11-26-2011 09:29 AM
mbuggy63
04-06-2011 11:13 PM
colemancb
03-26-2009 11:21 PM
ceres
02-12-2006 02:30 AM
