2001 sonata rear door handles don't work
Old 02-05-2009 | 08:03 PM
fuelman's Avatar
Question 2001 sonata rear door handles don't work
Hello all,
My son just bought a 2001 Sonata and for starters the Passenger side rear door handles don't work, I can't get the door open.
Is there a way to remove the door panel with the door shut?
Thank you for any help.
Old 02-05-2009 | 09:37 PM
ken99's Avatar
So the outside handle doesn't work either if the doors are unlocked from the driver's seat or with the fob? I guess I was wondering if the child safety lock had simply been set on that door.
Old 02-05-2009 | 10:24 PM
jsinton's Avatar
Banned
Looks like you might get the panel off without opening the door, looks like 3 screws and pop the plastic trim rivets:
2001 > G 2.4 DOHC > Body (Interior & Exterior)
REMOVAL AND INSTALLATION
a.
Remove the door window regulator handle and then remove clip using a piece of cloth (Manual type only)
[See large image...]
b.
Remove the rear door inside handle housing.
c.
Remove the mounting screws (3EA) from the rear door trim panel.
d.
Insert a trim panel remover between the trim fasteners and then remove the door trim panel.
e.
Remove the door pull handle mounting bracket and door inside handle.
f.
Remove the door trim seal.
g.
Down the door glass and remove the door glass run and delta lower channel.
h.
Remove the carrier plate mounting bolts from the door regulator channel and remove the door glass.
i.
Remove the door regulator channel mounting bolts and then remove the door regulator assembly.
j.
Loosen the door lock actuator mounting bolts and remove the latch assembly.
k.
Remove the door outside handle mounting bolts.
l.
Remove the waistline molding.
m.
Installation is the reverse of removal. When installing the door trim seal, butyl tape should not be place over door trim fastener mounting area.
hman567@gmail.com
03-28-2010 10:35 AM
lost6904
11-15-2008 03:22 AM
rowland0515
04-30-2007 02:52 AM
Stacey98Tib
09-24-2006 01:51 PM
xjdubber
01-18-2006 05:57 AM
