2001 xg 300
Old 09-17-2008 | 06:41 PM
bigsteve's Avatar
Default 2001 xg 300
I have a 2001Hyundai XG300 that is an intermittent no start. When you turn the key on, if you do not here the fuel pump initialize then it won't start. If you here the fuel pump it will start. Once it is running it will not quit till you shut it off. then sometimes it will start. The four codes that are reacuring are P1110 ets system malfunction, P1175 ets valve stuck close #2, P1191 ets limp home valve on, P1196 ets limp home close stuck. Has anyone ran into this problem or have any possible solutions? Any help would be greatly appreciated.
Old 09-19-2008 | 09:05 PM
jsinton's Avatar
Banned
Default RE: 2001 xg 300
[align=left]I found this:
"Answer
P1614 indicates an internal problem with the Electronic Throttle System (ETS) Module. This calls into question the validity of P0120 (throttle position sensor (TPS) A circuit problem), P0220 (TPS B circuit problem), P1110 (ETS malfunction), and P1175 (ETS close command malfunction). P1196 indicates that the bypass limp-home valve in the throttle body was opened, which is consistent with many ETS problems. I'd recommend starting with replacing the ETS module, clearing codes, and checking to see whether any of the other codes listed above return."[/align]
Old 06-01-2009 | 04:15 PM
m5james's Avatar
Banned
I have some of the same issues going on here, so can we get some more input and consolidate it onto this thread https://www.hyundaiforum.com/forum/s...hrottle+sensor since it's gotten more input. Thanks guys.
Old 06-01-2009 | 08:15 PM
ken99's Avatar
https://www.hyundaiforum.com/forum/s...ead.php?t=5207
gbrown
09-11-2008 09:19 PM
jeffmalarik
04-12-2007 02:03 PM
sonatalover
03-02-2007 02:42 AM
Coppertop
08-23-2005 11:58 PM
Quick Reply: 2001 xg 300
