2004 elantra blower switch issue
Old 11-27-2008 | 11:55 PM
thegdin's Avatar
Default 2004 elantra blower switch issue
i have a 2004 elantra. the air conditioner and heater work great. unfortunatly the blower only works on high (the highest setting being 4). everyting else works perfectly. the temp control andthe vent selector both work. also, the light is out only for the middle *** (blower controller i guess its called) and the air circulation button.
thnx in advance for your help.
BOB
Old 11-29-2008 | 12:06 PM
Freddie's Avatar
Default RE: 2004 elantra blower switch issue
If you have less then 60000 miles this would be warrenty. If not you need a blower resistor it is located on the bottom of the heater box between the blower motor and the console. As far as the lights the bulb can be replaced by pulling the control head from the dash. Th bulbs are common automotive bulbs avalible at any auto parts store.
Old 12-02-2008 | 09:00 PM
thegdin's Avatar
thnx for the help. im going to look into the warranty. i bought it used but if i remember correctly i bought an extension or something. gotta dig through the paperwork.
as far as doing it myself, (if its not under warranty) ill take a look at replacing the risistor. however, i think that might be a tad outside of my paygrade.
thnx again for the help....
MKOP
06-23-2012 10:30 AM
oknaz
02-08-2012 05:36 PM
Daniel.Brown
05-26-2010 10:04 PM
Cartaphilus
03-05-2008 04:26 PM
desarabme
03-06-2006 04:25 PM
Quick Reply: 2004 elantra blower switch issue
