2005 Tucson Error Code PO133
Old 08-17-2010 | 10:07 AM
Tucson2005's Avatar
Default 2005 Tucson Error Code PO133
120k miles. 2.0L engine. PO133 Error Code. I replaced the O2 sensor upstream of the pre-cat with an aftermarket O2 Sensor. No change. Then I swapped in a OEM O2 sensor. No change. Now what? Can the O2 sensor downstream of the pre-cat be having issues? Any help greatly appreciated. Thanks.
Scott
Old 08-17-2010 | 01:21 PM
Did you clear the code from the computer after the install?
If you replaced the O2 sensor and you are still getting the code, the problem could be an exhaust leak, a leak in the air intake tract, bad wires to the O2 or a problem with the MAF. First check for exhaust leaks, then intake leaks. After that check the O2 wires and connector). Lastly, check the MAF.
Old 08-17-2010 | 04:17 PM
Tucson2005's Avatar
Codes cleared after each oxygen sensor install. MAF cleaned and reinstalled. How would an exhaust system leak create a PO133 error code? Oxygen sensor wires checked out ok.
Scott
Old 08-17-2010 | 09:24 PM
I'd check for exhaust leaks first and then CHECK them MAF. Cleaning the MAF doesn't help if the MAF is bad.
I've seen people clean MAF thinking it will help (a different code) and it doesn't but when they replaced the MAF, the problem was solved.
https://www.hyundaiforum.com/forum/s...ead.php?t=8375
Old 08-17-2010 | 11:14 PM
Put the old sensor back in it (OEM), reflash the PCM for the #139 update, may have other unlisted jibberish in the update, it is for :
DESCRIPTION:
This bulletin provides information related to the ECM software update of some
TUCSON (JM) vehicles which experience a malfunction indicator lamp illuminated with
the ECM (Electronic Control Module) system-related DTC, P0111.
• P0111: Intake Air Temperature Sensor 1 Circuit Range/Performance
NOTE: There are no vehicle performance issues associated with this condition.
BE AWARE that the 0133 is seen a lot on ACCENT with craked front pipe (exhaust leak) but usually shows as a post cat ox code on Elantra (Tucson 2.0 is same engine)
chasf111
06-08-2011 07:24 PM
lone ranger
03-12-2008 03:49 AM
chesart1
11-22-2007 09:38 PM
chesart1
10-28-2007 04:49 PM
mtbreland
08-01-2006 11:38 PM
