97 accent electrical problems..help
Old 12-08-2005 | 10:35 PM
accentfamily's Avatar
Default 97 accent electrical problems..help
we have a 97 accent dash lights are not working, when key is turned off left side turn signals stay on all the time, also blinkers don't work. we have changed all bulbs with correct bulb spec. and replaced steering column light switch assembly. replaced all fuses under dash in fuse box and also fuses in fuse box under hood on drivers side any help would be great ,thanks
Old 12-09-2005 | 12:19 PM
poacher's Avatar
Default RE: 97 accent electrical problems..help
I had the same problem, but mine was a fuse. You might want to look behind the heater switch where the main wiring harness is, you may have a short.
patNV
02-01-2016 12:41 AM
askolepaul
12-01-2011 11:40 PM
mmenzies70
11-06-2009 10:31 AM
MiguelMckaintt
03-03-2007 08:20 PM
potential
01-23-2006 03:06 AM
