alternator removal
Old 08-09-2008 | 08:05 PM
harleyguy48's Avatar
Default alternator removal
Can anyone tell me how to remove the bottom bolt on the alternator of a 2003 Santa Fe 2.7. the bolt slides out towards the drivers side but hits a bracket for the axle that appears to be bolted to the transmission housing. do I have to pull the axle. Any help would be greatly appreciated.
Old 08-09-2008 | 08:34 PM
Default RE: alternator removal
You probably remove the bolt with the alternator. In other words, just pull the bolt out enough to get it out of the threads but leave the bolt itselfin the alternetor. Then pull the alternator out with the bolt still in it.
Old 08-11-2008 | 07:44 AM
Thanks for the reply. I tried to lift it out I do see the slot but wouldn't budge. Will try again maybe it is dirty and needs a little help.
Old 08-12-2008 | 10:55 PM
Thanks, a little persuasion and out it came. must of had dirt or something in the slot.
Sbrake
10-23-2017 05:20 PM
new dude
04-09-2013 04:55 AM
zainecurtis
04-05-2013 03:34 AM
ejames1226
02-11-2010 11:43 AM
reign_man
01-30-2006 06:28 PM
