Auto With Engine / Gearbox Issues!
Old 10-25-2005 | 04:36 PM
boozer_matt's Avatar
Default Auto With Engine / Gearbox Issues!
hey all.
i have a problem that i hope someone will be able to help me with.
basicly, the car is a hyundai coupe 2.0 SE (1999 model) & it is having some trouble.
it started off jumping gears when the engine was cold, but now it does it all the time & even stalls sometimes when i stop in traffic or at the lights.
i have been told it could be a problem with teh gearbox & i have also been told it could be a problem with the ECU, so i figured, i should register here & see if anyone can help.
i am going to try & reset the ECU by disconecting the battery for a while, but im not sure if that will work.
would love to hear if someoen else can help me tho.
cheers
MATT
Old 10-26-2005 | 01:53 AM
poacher's Avatar
Default RE: Auto With Engine / Gearbox Issues!
I'm not at all certain at what they may be. I had something similar happen to another vehicle I owned and by disconnecting the overdrive the problem was solved. Now it is nice to have overdrive and you can take that to a shop and have that repaired, but it may make your ride smoother until you do.
mbm
11-06-2010 09:25 AM
sonnyboy
08-18-2008 12:31 PM
00 Elantra
08-18-2008 12:17 PM
Chris0628
10-31-2006 02:18 AM
