balance shaft eliminator
hey guys i'm rebuilding the engine in my 2002 santa fe 2.4L and I'm going to eliminate the balance shafts, any advice on which kits to use. I'm currently looking at the one from slowboyracing.com. I know the engine code isn't a 4g63 but since its built very similar and it is a mitsubishi designed engine I figured it would work. I'm not trying to build a high horsepower engine since it is a santa fe, i'm just rebuilding cause one of the balance shaft bearing failed and scored the balance shaft journal. I figured it would be cheaper to just eliminate the shafts. Thanks for any advice
wheredoesthisgo
11-24-2007 06:25 AM
