Battery Light and overheating Sonata
Old 03-03-2007 | 10:03 PM
BigTexasFury's Avatar
Default Battery Light and overheating Sonata
Hi
Have a 2003 4cyl. Sonata
Suddenly the battery light is on, the shows that it's overheating (into the red) within 1.5 mile from home. Fan blows, but no heat or AC.
Also, after having to get a jump (brand new battery) now the speedo and tach are stuck at 40 mph even when the car is shut off...
Um, thoughts?
Thanks
Tex
Old 03-04-2007 | 02:07 PM
Chris B Williams's Avatar
Default RE: Battery Light and overheating Sonata
Hi Tex,
First thought is possibly the drive belt to the alternator/water pump has broken or come loose. Check this out first and adjust or replace as neccessary.
Regarding the speedo stuck at 40 mph and the tach. I havn't any real idea what could be causing this unless it it is due to the overheating.
Best of luck
Chris.
GoddessTink
11-02-2011 08:38 PM
glkpierce
10-25-2010 03:12 PM
djsgeym
05-13-2010 04:30 AM
vincewturner
06-18-2007 06:40 PM
