Changing Front Brake Pads 2000 Accent
Old 03-29-2010 | 06:14 PM
JayTye4k's Avatar
Default Changing Front Brake Pads 2000 Accent
Can I change these pads in typical fashion without the use of a hub puller? I'm hoping that is the case.
Thanks in advance for any help!
Jay
Old 03-29-2010 | 06:47 PM
Unbolt caliper from it' mounting, and swap pads if that is all you plan to do.
It would be in your best interest to remove the mount bracket, pop the shims off the mount bracket, and file the rust down to bare metal, then re-assemble shims. Now apply lube to the shims where the pads will slide, you want the padds to move freely in the mount, otherwise they will drag, that is why I told you the get rid of the rust.
I want to say the rotors should pop right off, I do not recall those being trapped behind the hub...
silvertones
12-20-2011 12:27 PM
tpx
01-02-2011 01:06 PM
Ed1976
09-17-2010 12:02 AM
steve1959
09-09-2006 12:23 PM
marauder
08-10-2006 12:10 PM
Quick Reply: Changing Front Brake Pads 2000 Accent
