Elantra Heating Problem
Old 11-29-2007 | 06:22 PM
barns123's Avatar
Default Elantra Heating Problem
When I stop at a stop light the heater blows cold air, when I start up it gets warm again. Any ideas?
Old 11-29-2007 | 07:25 PM
lighthouse1's Avatar
Default RE: Elantra Heating Problem
i would frist try a thermostat- feel top rad hose after car is warmed up if its only luke warm or cold good chance thermostat is sticking- and while just idling its not pushing enough hot coolant -but at higher rev it forces enough trough to get some heat
Old 01-22-2008 | 10:49 PM
jmdt1975's Avatar
ORIGINAL: barns123
I have the same problem with my 2002 elantra, but it also has the same problem for the A/C in the summer. In both cases everything is fine, until I stop or am coasting or something that brings the engine RPM's down and then I just get outside air - cold in the winter, hot in the summer. If I rev up the motor then things work as expected. My mechanic says the two systems, heat and A/C, are separate and unrelated, but it seems to me that these problems are connected somehow. Any ideas?
maabel
03-30-2009 01:39 AM
dsrming13
11-12-2008 12:39 PM
mrchris
12-30-2007 03:21 AM
augu.stas
11-06-2007 09:15 PM
rw02kr43
02-21-2007 03:25 PM
