engine blown 2005 elantra
Old 04-24-2006 | 06:09 PM
stuckwith hyundai's Avatar
Default engine blown 2005 elantra
19000 miles engine blown...valve went threw piston...hyundai says it was my fault because for some reason the engine got to much oil pressure and caused the engine to blow..would not fix...can anyone tell me why the oil preeure would spike or is it there way of sticking it to me
Old 04-24-2006 | 06:27 PM
flave1's Avatar
Default RE: engine blown 2005 elantra
if your motor has still got warranty and you have not modified the engine there is no reason why your dealer should refuse to fix it. sounds like they are givin you the brush off imo.[sm=bicker.gif]. where in the world are you????
Old 04-24-2006 | 08:39 PM
serviceguy's Avatar
SWH,
WHat's the story? Most dealers do not deny warranty without a good cause. Oil pressure issues are usually only caused by a non-Hyundai oil filter (there is a bulletin for this), or a failed oil pump. I would like to know what happend and why the dealership came to the conclusion they did.
Serviceguy
Old 04-25-2006 | 11:42 AM
frozeh2o's Avatar
How can an engine get too much oil pressure unless something did go wrong with the oil pump in which they should replace because of the warranty?And how can they blame you unless it was a wrong oil filter on the car?I would definitely want more of an explanation from them that the one they gave "for some reason" it blew and it was your fault.[sm=bs.gif]
Old 04-25-2006 | 04:35 PM
Doohickie's Avatar
Yeah... there is a TSB out on aftermarket filters. I understand Fram no longer lists many Hyundai applications. If you went to an oil change place and they put a Fram filter on, they are the ones that are liable (for using the wrong filter). Find out what filter is on there, and check an application book (at a store where you can buy that brand of filter) to see whether they list your car as an application for that filter. If not, then whoever put that filter on is at fault.
Old 08-26-2006 | 12:07 AM
graham7773's Avatar
Well!!! I was just about to fit a FRAM oil filter to my 1.8l twin cam 16v 1994 Elantra (Lantra) when I saw this post. What is wrong with FRAM filetrs?
tsherv
12-15-2014 09:50 AM
blank
03-22-2011 08:29 PM
bighead4570
01-26-2010 08:02 AM
David Eagle
10-19-2009 06:28 PM
hunteryarbrough
09-02-2008 01:35 PM
