engine stumble
Old 02-06-2006 | 10:50 PM
onetimer's Avatar
Default engine stumble
Im baffled,
i have a 98 tibby 194000kms on it and I've been having the weirdest trouble with my car. It happens when the engine is hot and im in traffic when I go to accelerate the engine cuts out for a second then keeps on going this will only happen in 1st or 2nd gear.
the check engine light came on so I went to the dealer to have it scaned, it came up as evap leak meaning that there was a leak in the fuel system the techs were baffled and tried the one thing that has been a problem with santa fe's they changed that purge valve for the evap canister. Well that fixed the problem for a while but now the problem is back just has before.
has anywone ever had this problem before
Old 02-08-2006 | 04:45 PM
poacher's Avatar
Default RE: engine stumble
It may be a vacuum line. Have you checked those yet?
Old 03-08-2006 | 12:53 AM
tenick's Avatar
Does it feel like it just "falls on it's face"? I had that problem with my XG-300 and after several trips to the dealership, it still couldn't be diagnosed. We finally found a certified technition who found it to be a faulty ignition module. Your model seems to be outside the year of the specific recall, but it may be worth looking into.
Old 06-08-2006 | 04:17 PM
onetimer's Avatar
Thanks for the advise it ended up beeing a cracked exhaust manifold that was affecting the O2 sensor readings.
Carl-in-la
03-03-2015 11:39 AM
benballXG350
05-09-2013 03:24 PM
FL_Smokin_PSD
01-24-2009 07:49 PM
