Idles at 3000-4000rpm.
Old 08-27-2006 | 11:47 AM
hyundaisam's Avatar
Default Idles at 3000-4000rpm.
2001 Accent, 5 speed. When started warm or cold engine idles at high rpm. No tach to make sure but its high, 3000-4000 range. What sensor could this be? TPS, MAF,.....??????. Reseting the ecu works for about two or three weeks. It also does it without the check engine light on, but most of the time it is illuminated. Any help would be appreciated? Sam
Old 08-27-2006 | 03:42 PM
duke's Avatar
Default RE: Idles at 3000-4000rpm.
most likely a TPS problem. one should never reset the ECM without reading the coeds first.
Sylander
11-17-2023 07:02 AM
bicheck
05-26-2015 04:17 PM
bboystunts04
06-11-2010 11:15 AM
raycraft
03-20-2010 07:44 PM
powercoll
02-21-2007 04:27 PM
