Need wiring assistance scoupe + elantra mix
Hi
I need help for marrying my electronics, i have to set up elantras main harness in scoupes dash connector. this is what i need:
92´ Scoupe 4G15 full setlist for these two connectors: MC01 , MC02 , total 26 wires (in the engine harness, connects to dash.)
91´Elantra 4G61 DOHC one connector: MC01 total 21 wires. (same as above)
THX
THX
RE: Need wiring assistance scoupe + elantra mix
The only thing I can think that may help would be to register with http://www.hmaservice.comand try to look up the harnesses for them (look under "ETM"). If you aren't in the U.S., it will ask for a postal code/zip code. 48124 is a valid number to put in for that. I'm not sure the data goes back that far though. Good luck.
