Oil in air filter hose?
Old 09-01-2007 | 06:20 PM
Whitaker5's Avatar
Default Oil in air filter hose?
I hope someone can help.I've been having some problems (burning plastic smell, remote starter/lock not working right) with my 1998 Sonata GLS (6 cylinder) and when I was looking at it today, I took off the air filter hose and there was oil in it. Does anyone know what would cause this? Should I bring it to the dealer? Thanks in advance for any help you can offer.
Old 09-04-2007 | 09:36 AM
Default RE: Oil in air filter hose?
It's oil vapor from the crankcase being pushed into the intake from blowby pressure. How old is the PCV valve? It probably needs to be replaced..
Old 09-04-2007 | 09:25 PM
Whitaker5's Avatar
Not sure how old PCV valve is, I've had the car 6 years and haven't replaced it. I will try that and see if it solves the problem. Thanks for your help.
Old 07-12-2008 | 05:34 PM
Bill McGraw's Avatar
Just wondering if you got your problem fixed? I have a 2003 elantra with the same problem. I have replaced the pcv valve and that didn't help.
Old 07-23-2008 | 09:52 AM
SHOZ's Avatar
Try some Auto-RX. http://www.auto-rx.com/ It will slowly clean the carbon from behind the rings and reduce the blowby.
Paulus
03-11-2013 10:29 AM
Aggie_1990
01-17-2012 12:28 PM
mrmr256
12-08-2011 09:54 PM
took
03-27-2010 12:28 PM
valleydavid
10-29-2007 12:07 PM
Quick Reply: Oil in air filter hose?
