Oil Pan Replacement
Old 05-17-2008 | 02:35 PM
bernd's Avatar
Default Oil Pan Replacement
I recently replaced the rusted out oil pan on my '97 Elantra. It did NOT come with a gasket, but there was one available,
sold separately. I bought the paper gasket anyway thinking that it must need a gasket. However, when I took the old pan off, there was
no evidence of a previous gasket. I put everything back together using a gasket, but it just didn't seem to bolt together correctly.
In fact, upon tightening the bolts, I split the gasket in a couple of places.
OK.. take it all apart, clean everything, reapply gasket sealer without the gasket. It bolted up much nicer.
However, its 2 weeks later and there is fresh oil leaking out from most of the seam around the pan.
The bolts are already pretty tight. I can't see getting them much tighter.
My questions:
The pan is not made to run with a gasket, right?
Can I just go around the pan after cleaning the edge and apply a coat of gasket sealer, or am I going to
have to do this all over again??
Thanks!
Old 05-20-2008 | 05:29 PM
bernd's Avatar
Default RE: Oil Pan Replacement
Follow-up..
Heres what I decided to do. I tore the entire thing apart.. again. I scraped off the old material, cleaned both surfaces,
and really piled on the black RTV. I let everything sit overnight, and then went around the edge of the pan where it meets
the block, and added more RTV. I hope it holds!
As far as I can tell, there is no mention of using a gasket on the oil pan on the hma website or the Haynes manual.
Old 05-21-2008 | 11:13 AM
RknRusty's Avatar
Unless one of our resident experts says otherwise, if it leaks again, clean up the mating surfaces and use a noprene gasket. If you wish, you can apply a bead of sealer on both sides of the gasket too.
luminessa08
05-06-2014 01:39 PM
blueshark
03-19-2012 03:45 PM
meld
08-05-2010 06:53 AM
Rhondas
11-05-2008 10:46 AM
BobMcLean
12-18-2005 03:52 PM
Quick Reply: Oil Pan Replacement
