Oil Pump Pickup Tube Question
Old 05-04-2008 | 07:34 PM
bernd's Avatar
Default Oil Pump Pickup Tube Question
'97 Elantra
I am replacing the oil pan, and of course, the oil pump pickup tube is exposed. I am wondering if there is a flat gasket or an O-ring between the tube
assembly and the pump, and if it should be replaced while I have the oil pan off? I am not inclined to take it apart unless I know it should be replaced.
If so, do I need to get the gasket from the dealer or will any parts store have it? Otherwise, I'm ready to put everything back together tomorrow evening (5/5/08)
Thanks!
bernd
Howes Cave, NY
Old 05-04-2008 | 08:51 PM
Doohickie's Avatar
Default RE: Oil Pump Pickup Tube Question
I'm not sure, but if you don't get a more definitive answer from someone else, I would recommend not messing with it and putting it back together.
Old 05-04-2008 | 08:55 PM
bernd's Avatar
Thanks.. I think thats an answer I can live with. I was thinking the age of the gasket may affect the pickup tube seal after a time as there is 192kmi on this car.
Old 05-04-2008 | 11:38 PM
RknRusty's Avatar
Sorry I don't have the exact answer because I've not yet been into a Hyundai engine, but generally, if you have the pan off, you should always replace what's recommended on an oil pump. It is, of course, critical to the health of your power plant. I always rebuilt the oil pump when opening the bottom end of all the V8's I've worked on.
Old 05-05-2008 | 12:22 PM
bernd's Avatar
Thanks, but I'm not rebuilding the oil pump. That is accessed from behind the crankshaft pulley, and thats a whole different job in itself. I only have the oil pan off. I was just wondering if the oil pump pickup tube gasket is something that should be replaced while the oil pan is off.
Old 05-05-2008 | 12:34 PM
ORIGINAL: RknRusty
The Hyundai 4-cyl is not a V8. The oil pump is part of thecover attached to the front of the engine. It's not inside the oil pan. Unless there is a problem with the pump, there is no need to rebuild it.
ORIGINAL: bernd
Unless you need to take the tube off the pump or if you can see physical damage to the gasket, there is no need to replace the gasket.
Old 05-05-2008 | 10:44 PM
RknRusty's Avatar
Now I see, thanks for that diagram.
Old 05-06-2008 | 08:52 AM
I know you said you are still learning the Hyundai (so am I). I'd suggest going here and signing up for access (it's free): http://www.hmaservice.com/
It has all sorts of service info, diagrams, TSB's and other info about almost all US Hyundai vehicles.
Old 05-06-2008 | 10:05 PM
RknRusty's Avatar
Thanks Nova, that looks like a lot of good information.
ded548
08-05-2015 09:25 AM
swenrac
Off Topic
05-18-2010 11:46 AM
DrDemento
02-25-2010 01:18 AM
joeym
03-15-2009 01:10 PM
bajohnselantra
02-17-2008 08:24 PM
