oil on spark plugs
RE: oil on spark plugs
Better fix it immediately, because when my friend had taken for granted the oil in the spark plug of his jeep it cause some serious problem in his Jeep starter. His mechanic told him that oily coating caused by poor oil control. Oil is leaking past worn valve guides, piston rings, or on some race engines a possible intake gasket leak and then entering the combustion chamber. Try checking for worn valve guides, intake gasket sealing alignment, as well as worn cylinder walls and piston rings. A leak down test is a good place to start for what is causing this... Goodluck...
ORIGINAL: moonz
Long-term solution...new valve-seals, or maybe a ring-job...short-term solution...shorter reach sparkplugs that don't get as wet with leaking oil as ones that protrude further into the cylinders.
I'd hate to see you do "new valve-seals, or maybe a ring-job" when it may only be a bad ($3.00) PCV valve or clogged hose.
ORIGINAL: Michaels10
how much oil?
enough to foul them
how much oil?
enough to foul them
ORIGINAL: famous
oil on spark plugs - 4/5/2007 7:25:46 PM
i just changed my spark plugs and #2 and #4 has oil on them what is that from and how can i fix it
anonymouse
05-10-2010 02:32 PM
