p1602 code
p1602 code
i have an 01 elantra with a p1602 code from what i found the tcu communication line 1 is malfunctioning....anyone know if thats correct, whatexactly that means and how toget rid of the code??? any help would be appreciated. thanks
RE: p1602 code
I was reading where this happens when you get a voltage drop when you disconnect the battery. You clear it with the same code reader you got the code from. Sounds like a not-to-worry thing.
blackbox19
08-06-2010 10:59 PM
