Performance issue
Old 07-27-2012 | 10:01 PM
Originally Posted by TouringDude2012
I have found out Rad fans on Hyundai's don't come on until it's really hot or the A/C is on.
That's normal for all cars, not just Hyundai.
The engines are tightly packed and heat up quickly once you turn the car off,
Again, all cars are that way.
it is strange that Hyundai doesn't have cooling fans engage without the key in the ignition and they rarely come on during idling after running hot (bad engineering design in my opinion)
It's not bad engineering, it's to prevent the battery from draining. If the fans ran every time you shut the car off the battery would die. The fans use a lot of power and should only run when the engine is running and the alternator is supplying power.
I almost wonder if all Hyundai's suffer from too much heat and that added heat wears things out faster than norm.
No. Modern engines are designed to run hot. It's better for fuel economy and cleaner emissions.
jalexa101
06-27-2011 07:49 PM
scott
12-09-2005 06:38 PM
accountnat
12-09-2005 01:29 AM
aaloe1017
12-07-2005 03:36 PM
JGeZau
06-26-2005 07:07 PM
