Rotors: To turn or not to turn?
Old 07-31-2006 | 07:13 PM
ttewejnodnarb's Avatar
Default Rotors: To turn or not to turn?
Hello,
I'm new to the forum and to working on my car. I have a 2002 Accent and replaced the front brake pads recently. The dealer wanted almost $500 to replace the pads and turn the rotors but I couldn't spend that much. I just took it to a Pep Boys to replace the rear shoes (I couldn't break the drums free or I would have given that a shot too) and they said I needed to replace the pads AND rotors in the front. Here is my question:
There is no pulsing from the brakes. Do rotors need to be turned EVERY time you replace the pads? I put the pads in according to the service manual but didn't have the tools to check runout (again, no pulsing)...could I have destroyed the rotors by not having them turned the last time? They look to be in good shape, no deep grooves, etc. I just have this sneaking suspicion that both the dealer and Pep Boys are exagerating. What's the real story?
Any help would be greatly appreciated.
Thanks
Old 08-10-2006 | 05:58 PM
flave1's Avatar
Default RE: Rotors: To turn or not to turn?
if the brake disc doesnt have a raised edge on the outer and inner disc then it should be ok (hard to tell without seeing them)
Old 08-11-2006 | 02:54 PM
cofreth's Avatar
Usually 3 sets of brake pads equals to one disc.
Old 08-28-2006 | 12:36 PM
fritz's Avatar
Depending upon your driving habits, rotors may need changing more frequently because they are made thinner. I had to change a set of front rotors for another make of car at 42,000 miles.
cosmo
09-29-2006 03:04 PM
snoopy693
07-17-2006 06:24 PM
TruSake
06-11-2006 04:04 AM
tburon fx
03-31-2006 07:43 PM
miatawnt2b
11-04-2005 07:12 PM
