Rough Idle
Old 09-22-2005 | 05:30 PM
ogman99's Avatar
Default Rough Idle
Hi
I have a 1996 Elantra and I recently replaced the Fuel Pressure Regulator and the Mass Airflow Sensor. I now have a rough idle. I checked the voltages on the MAS and the Throttle Postion Sensor and both appear to be correct. Is there a way to check the Idle Speed Control Actuator?
Old 09-27-2005 | 08:45 PM
Patrick's Avatar
Administrator
Default RE: Rough Idle
first, check to be certain that from your MAFS to the TB you have good seals everywhere..i had an idle issue because of a crack in my air tube between the MAFS and TB
jbragg923Justin
11-14-2007 09:47 AM
keiffer
06-09-2006 01:02 AM
nmedeiros
01-18-2006 03:48 AM
dave1234
12-22-2005 10:36 AM
L2rocku2
08-03-2005 01:57 PM
