rpms still going when out of gear
Old 03-29-2006 | 01:53 PM
AAREN81's Avatar
Default rpms still going when out of gear
can anyone help me please..... i have a 2001 elantra and when i am driving if i take it out of gear..a nd start using the brakes the rpms go to like 3 grand...when i evently stop and when i tap the brakes it goes away. this has happened once before but it went away after a week or so.... can anyone help me......please...
Old 03-29-2006 | 08:10 PM
poacher's Avatar
Default RE: rpms still going when out of gear
I'm guessing its a stick? It could be your throttle positioning sensor.
Old 03-29-2006 | 08:34 PM
AAREN81's Avatar
yeah it's stick.. that is what my boyfriend said but he wanted to make sure... he said that i would probally have to call the dealership and pay an arm and a leg for a new one... unless there is something else i can do.....
Old 04-01-2006 | 05:39 PM
gadgetman's Avatar
The engine computer sees a signal that the car is moving and keeps the rpm's up to keep emissions lower. I don't remember how high the rpms go but even when I had a car jacked up and running, if a wheel was turning the rpm's would go up.
Old 04-01-2006 | 11:07 PM
AAREN81's Avatar
then why after 60 thousand miles it just started to do it.it will stay ay whatever rmp you have the gas at when you push the clutch in when comming to a stop.it doeasnt raise it just stays at a staedy rpm.
Old 04-12-2006 | 11:46 PM
gadgetman's Avatar
You could take the air intake hose off at the throttle body and look at the throttle plate and clean it with some 2+2 carb cleaner. and make sure the throttle cable isn't too tight at the throttle body.
Old 04-13-2006 | 01:24 PM
duke's Avatar
this looks more like a problem with the TPS
murkstreaks
12-08-2011 09:51 AM
old mark
04-11-2011 08:02 AM
tractorboy
03-30-2010 11:42 PM
Veneetraj
02-15-2009 02:33 PM
