Sluggish Shift on a Sonata
Old 11-04-2007 | 04:08 PM
itskeiser's Avatar
Default Sluggish Shift on a Sonata
Hey guys, any help on this is appreciated:
I revently got an 01 Sonata automatic, and about two months in Ive noticed its shifting bad- it locks up at 5x rpms until I take my foot off the pedal, than it switches to the next gear. Also, on the third gear it jumps awkwardly to 4-5x rpms the moment it switches, almost like its slipping and going right back to second.
I had a similar problem on my focus and all that needed was an oil change, but this seems worse. Any ideas?
Thanks Again
Old 11-04-2007 | 06:37 PM
Joshewuhh's Avatar
Default RE: Sluggish Shift on a Sonata
Have the trans fluid serviced first and go from there.
Contaminated fluid can cause the symptons you are describing.
Old 11-05-2007 | 03:27 PM
HYUNDAI35's Avatar
Is your check engine light coming on?
Old 11-05-2007 | 04:57 PM
itskeiser's Avatar
Yea its popped on a few times for a couple minutes
Old 11-05-2007 | 06:38 PM
HYUNDAI35's Avatar
Get that checked out first- could be a Throttle Position Sensor or an Output Speed Sensor. What you DON'T want to see is DTC P0734...........that's badness.
Old 11-07-2007 | 08:49 PM
itskeiser's Avatar
Got it checked yesterday-they said no check engine light came on for them and the diagnostic revealed no error codes.
So it seems the trans fluid is the culprit.right?
Old 11-08-2007 | 11:47 AM
HYUNDAI35's Avatar
Maybe..... don't get your hopes up, though. You might try getting a priest to bless the new transmission fluid before you put it in.
Good luck!!
Old 11-08-2007 | 05:32 PM
Joshewuhh's Avatar
How many miles are on the car?
If more than 60k... its time for a trans service without a doubt.
hxc-fuk
03-22-2011 05:55 PM
ElantraMan
04-22-2010 11:20 AM
JCorcho
04-06-2010 06:41 PM
thumper
02-11-2008 01:21 PM
Bonerable
12-18-2006 02:45 PM
