spark plugs hyundai XG300
OK where are the things hiding.. I took the top cover off and found 3 but I have had 4 people look and read the book and there is no mention as to where the rest would be.. I admit it is a dumb question but I know no where else to turn.. One person said to take the intake manifold off but then do i need a new gasket as well???? Please help a lost person
D-
D-
RE: spark plugs hyundai XG300
The V6 engine is mounted sideways in a front wheel drive car. That means 3 are in the front and 3 are in the back of the engine by the firewall. Whoever told you to take the intake manifold off is correct. However, you only have to take off the upper intake manifold. That will give you access to the rear 3 plugs.
This is on a Tiburon but the procedure is the same.
http://www.newtiburon.com/forums/showthread.php?t=70634
This link has pictures but it does both the upper and lower intake. You only have to remove the upper intake:
http://www.newtiburon.com/forums/showthread.php?t=1760
Do you need a new gasket? Well, some people have reused the original because you are only sealing air (not fuel, oil or coolant) but a new one is cheap insurance.
