stuck at home, tranny problems..please advise!
It all started last Sunday I was driving and I felt a thud..but my car continued to drive like usual.
I pulled into a store and parked, went in and came out....Reverse no longer worked when I went to pull out of the parking lot! I was able to get it pushed out of the parking spot so I drove around the lot to sort of see what else might happen.
Everything was okay. For a moment. Then I stopped and went through the gears to see what would happen.....a few clunking noises (scary) and I was on my way.
I was able to drive home safely.....going about 20mph, running about 4000 rpm.
Following are a few theories I have established:
-need new tranny (worst case scenario)
-possible cylinoid issue
-speed sensor maybe?
-transmission flush needed
What do you think????
RE: stuck at home, tranny problems..please advise!
I do not know much about Hyundai transmissions but normally when you cannot get into the gears, they are gone. You could start with a flush (cheapest as far as I know), but that might lead to having your car stuck at the shop if the problem is bigger.
Good Luck
~work~
Good Luck
~work~
Yes, if your reverse worked ok before you replaced the clutch, and now it won't make reverse, then assume there must be some sort of cable adjustment. I never tried to adjust them myself, but I would start by removing them from the top of the trans to see if they will adjust. Don't know if they need to be longer or shorter.
Are you sure you didn't get the cables switched around the wrong way?
yes quite sure. as a matter of fact when I took it into the dealership they commended me on the good job i did replacing the clutch. the problem was something else entirely. Im creating a new thread to warn EVERYBODY!
https://www.hyundaiforum.com/forum/s...ead.php?t=5757
birdmantechman
04-22-2006 10:27 AM
