trouble code P0301 any help?
Old 10-26-2007 | 06:04 PM
~work~'s Avatar
Default trouble code P0301 any help?
I have been sorting thru posts and replies in this forum for over 3 hrs now and cannot seem to find anything on this trouble code
P0301
I know it can be one of the following things:
Ignition System Fault ( already changed the plugs and wires )
Vacuum leak (checked, nothing found)
Fuel Injector Fault (any help on how to check this)
High or Low Fuel Pressure (trying to avoid going there)
Vehicle: 2000 Hyundai Elantra 2.0 Manual Trans. 130,000 miles
Any help would be great
Old 10-27-2007 | 12:21 AM
WheelBroker1's Avatar
Default RE: trouble code P0301 any help?
Hi Member:
The code you put in there can be caused by multiple cylinder misfireing from cylinder #1...Check for faulty spark plugs, wires and coil, also check for vacume leaks and even fuel injector problem...have a fuel pressure check done by someone who knows what theyre doing..Hop this Helps you out:
WheelBroker1 [sm=americanasmiley.gif]
Old 10-27-2007 | 05:05 PM
Joshewuhh's Avatar
If you had a bad injector, your car would be running very poorly.
When was the last fuel filter change?
Fuel pressure drops are 9/10 a clogged filter or the fuelpump failing.
Old 10-28-2007 | 07:09 PM
lighthouse1's Avatar
po301 - is missfire #1 cycliinder most likely on a elantra its plug wire - or plug /coil
Old 10-29-2007 | 11:55 AM
Doohickie's Avatar
I would say most likely is a coil pack problem.
Old 10-30-2007 | 01:30 PM
HYUNDAI35's Avatar
ORIGINAL: Doohickie
What he said--- wire, most likely.
zx6star
10-03-2013 07:36 AM
Varies
08-07-2012 12:48 AM
Sevin
04-08-2010 12:21 PM
skipi
11-30-2008 04:25 PM
2000ELANTRA
08-01-2007 10:28 AM
