Washer pump not working
Have a 2014 accent and I知 not receiving any power to the washer pump connector..(replaced the windshield wiper/washer switch,and checked fuses on both d cab block and under the hood however, I知 not sure if the relays would b the problem)..the eiper funtions on both, yhe rear and front are perfectly funtional.Any hints?
Before replacing any more parts suppose you try the following,
A test light is the quickest and easiest tool to use.
Clip the ground clip to a known good ground and then check to see if there is power available to the switch with the key on, if so ,operate the switch and see if it sends power out to the washer motor. Let us know what you find and we can go from there.
