Where is the ETACS on a 2005 Hyundai Elantra?
Old 09-27-2008 | 12:45 PM
benrand's Avatar
Default Where is the ETACS on a 2005 Hyundai Elantra?
Where is the ETACS on a 2005 Hyundai Elantra? If it doesn't have one what causes the alram, dome light, radio and clock to not work all at once? I check all the fuses inside the car (to the left of the steering weel under the storage bucket) and under the hood and all are in good condition. From reading I thought it sounded like the Etacs but I don't know what it is or where to find it!
Thanks
Ben
Old 09-27-2008 | 02:50 PM
ken99's Avatar
Default RE: Where is the ETACS on a 2005 Hyundai Elantra?
1.Disconnect the negative (-) battery terminal.[/align]
2.Remove the 2 screws(A) holding the instrument facia panel.[/align]
3.Remove the ash tray then remove the 2 screws(A) holding the instrument facia panel.[/align]
4.Remove the instrument facia panel.[/align]
Remove the air conditioner switch panel(A) after removing 4 screws.[/align]
5.Remove the ETACS module (A) after removing 2 bolts.[/align]
I still think you have a blown fuse. Double check the fuse labeled "ROOM LP" on the interior fuse block as indicated on page 6-35 of the owners manual. Pull it and give it a close look or test with an ohmmeter.
Old 11-15-2008 | 03:50 PM
gfugate's Avatar
Did this fix the problem? My girlfriend's 2005 elantra just did this. I swapped the fuses between nthis and a working system and nothing changed, suggesting the fuse was not at fault.
turbo15479
08-23-2012 02:44 AM
akawood
12-16-2011 11:48 AM
JSchna
08-31-2010 11:47 AM
kevkel33
02-12-2008 12:20 PM
elantra1
12-08-2005 07:38 PM
