will not shift out of park
Old 10-20-2008 | 08:33 PM
kslim's Avatar
Default will not shift out of park
points to possible brake light switch all fuses are good if brake light switch is the fix how do you get at it, it looks like its right above steering line
Old 10-21-2008 | 08:10 AM
Default RE: will not shift out of park
What vehicle?
Old 10-21-2008 | 12:49 PM
kslim's Avatar
05 hyaundai accent
Old 10-22-2008 | 09:49 AM
kslim's Avatar
brake light switch is good,all fuses good still no brake lights and will not shift out of park
Old 10-22-2008 | 01:45 PM
How do you know the switch is good? If you are not getting brake lights the switch is probably bad.
See switch location here:
Old 10-22-2008 | 01:46 PM
Check the stop lamp switch:
(1) With an ohmmeter connected to the stop lamp switch terminals, check for continuity.
(2) If there is no continuity when the plunger is depressed and there is continuity when the plunger is released, the stop lamp switch is normal.
Old 10-22-2008 | 02:26 PM
kslim's Avatar
I verified with a meter was able to see switch open and close as I pushed in on switch while connected to meter what is left to check I was told that there is a solonoid somewhere in the system if this is true where is this located
Swiper99
04-04-2018 04:35 PM
Jennifer Rospad
08-03-2012 10:52 PM
chris13
04-02-2009 09:51 PM
blueslover
12-31-2008 01:59 PM
apriliaalex
08-23-2007 08:27 AM
