Wireharness
Old 03-31-2008 | 10:42 AM
eyedea40's Avatar
Default Wireharness
Last week some one stole my radio from my 99 Hyundai Sonatta, They did such a wonderful job they pulled the factory wireharness right from my car. Does anyone know where I can get a factory wireharness? I mean the one that plugs directly in to the stock radio.
Thanks.
Old 03-31-2008 | 10:56 AM
Default RE: Wireharness
Sorry to hear that. My guess would be either a Hyundai dealer (expensive) or a local junkyard. You might also find something on eBay. Good luck with that.
Old 03-31-2008 | 03:27 PM
ken99's Avatar
Sorry to hear about your loss. I assume you mean the thieves simply cut off the wires below the male connector that plugs into the stock radio. A company called "Scosche" makes car radio harness pigtails that are direct replacements for the male end plugins on the car's harness (they call them reverse harnesses). Goto:
http://www.scosche.com/products/sfID.../158/sfID3/178
for pages and pages of them. I did a quick check and found this one:
http://www.scosche.com/products/sfID.../productID/601
which fits 2000+ Sonatas & Accents. I also found this one:
http://www.scosche.com/products/sfID.../productID/599
for 1992+ Hyundai cars. Either will likely work (they look the same or similar). The wires on the pigtail need to be matched up to the wires in the dash and then either crimped or soldered together. If you also order the counterpart female pigtail, you can easily wire up any aftermarket radio that will fit the dash...and easily remove it if you decide to get rid of the car. I wish you luck.
Old 04-02-2008 | 09:18 AM
eyedea40's Avatar
Thanks for all the info; I found a cheap factor wire harness on eBay last night. It seems they were listed under OEM harnesses. My next question, where can I locate a wiring diagram? I know the striped ones are speakers yellow power, but it seems I am still missing a ground wire somewhere. They did a number when ripping the radio out.
Old 04-02-2008 | 10:36 AM
ken99's Avatar
Here are a couple of threads where radio connections are discussed, including some graphics indentifying the wire layout and colors. These are for 00 through 04 Sonatas, but I think Hyundai has been consistent with the basic radio wiring scheme for sometime.
https://www.hyundaiforum.com/m_12472/tm.htm
https://www.hyundaiforum.com/m_12618/tm.htm
P.S. Your 99 Sonata is a "EF" variant, the same as the 2000 through 2004. The above links should be directly applicable.
