03 Accent...will not shift
Old 02-18-2008 | 01:45 PM
caper's Avatar
Default 03 Accent...will not shift
I have a 2003 Accent. It is an automatic but will not shift into fourt gear. I it fine in the lower gears but once you get going just won't shift, . Does anyone know what the problem might be. Thanks alot.
Old 02-18-2008 | 06:57 PM
ken99's Avatar
Default RE: 03 Accent...will not shift
Three questions:
1) Is the check engine light on the dash lit?
2) How many miles on the car?
3) Have you recently checked the ATF fluid level in the transmission?
Old 02-19-2008 | 12:55 PM
caper's Avatar
No, the check engine light is not on. I think there is a problem with the wiring. Some of the other dash lights don't work either. T here is 150 km's on the car and the transmission was just flushed and there is new fluid and it is fine.
I think the problem is with the Over Drive switch on the gear shifter. It is driving like the OD is off. Is there an easy way to get at this switch on the shifter. ???
Old 02-19-2008 | 01:07 PM
Doohickie's Avatar
Which fluid was used for the flush? The only correct answer is SP-III. If you went to a shop other than a Hyundai, Kia or Mitsubishi dealer, they probably used something called "universal synthetic" which can damage Hyundai automatic transmissions. It's not truly universal. From the owners manual, "Use HYUNDAI GENUINE ATF SP III, DIAMOND ATF SP III, SK ATF SP III or other brands approved by Hyundai Motor Co., when adding or changing fluid. Using the wrong ATF may result in damage to the ATM." Hyundai or SK ATF SP III can be bought at Hyundai and Kiadealers, and Diamond ATF SP III can be bought at Mitsubishi and some Chrysler dealers.
If the wrong fluid was used, you may have to get the transmission shop to repair the tranny at their expense, since they used the wrong fluid.
Old 02-20-2008 | 01:21 PM
caper's Avatar
I found the problem. There was a small wire running from the Over Drive switch that was broken, causing it to no go into overdrive..... Spliced the wire and everything woks fine.
Ranga
05-28-2011 09:54 AM
nester521
05-11-2011 12:04 PM
hamad4
03-14-2010 11:44 AM
kslim
10-22-2008 02:26 PM
orion30
07-07-2007 03:15 PM
